Ebpv Does Not Work!
Old Jan 2, 2005 | 09:06 AM
18vtx00's Avatar
18vtx00
Originally Posted by slc10844
Oil temp below 167*F, IAT below 45*F, 5vdc. According to the book, ECT controls fuel delivery.
this is what is was looking for thanks alot
Old Jan 2, 2005 | 09:07 AM
18vtx00's Avatar
18vtx00
Originally Posted by mr_fixit
I had the sensor go bad and it stored a code in the pcm . Until you clear the code the valve will not operate.
no codes but i did notice that on my datastream the exh back pressure read higher than i expected. i think it was 15-17psi.
what is the spec anyways.
thanks.
Old Jan 2, 2005 | 10:52 AM
mr_fixit's Avatar
mr_fixit
Is that at idle? If you do a KOER test it should test the valve and you hear the idle go up and the valve will close and a hissing sound if all are good.
Old Jan 2, 2005 | 11:19 AM
18vtx00's Avatar
18vtx00
yes at idle and 2000rpm, i believe that was the #'s. KOEO OR KOEO did not show any codes.
but they almost never do.
i was told here that this year 96 truck does not idle up.
