3 on the tree
Old Jan 1, 2005 | 04:27 PM
nlok's Avatar
nlok
Question 3 on the tree
Im going to be doing a transmission and engine swap in the near future and getting rid of the current 3 on the tree setup ... should I switch it over to a 5 speed or a 4 on the floor? and how hard is it to do?
Old Jan 1, 2005 | 06:21 PM
SSCX2's Avatar
SSCX2
It's not too hard to swap it over, the clutch pedels are there so basicly all you need to do it cut a hole in the floor board or find a peice from a standard trans truck with the hole already in it. I personally like manual 3 speed transmissions keeps the floor clear, my 76 chevy is a coulmb shift HD muncie. I like the fact that most people dont know how to shift them so they dont ask to drive it not that I dont trust people with a truck that runs low 11's
Old Jan 2, 2005 | 10:33 AM
bremen242's Avatar
bremen242
the 5 speed will be a pain. I'd use a regular 4 speed.
you have to cut out the hole in the floor pan (a sawzall works nice), and get a transmission tunnel cover from a truck that has one (make sure you get the shifter boot, cuz they are expensive!).
after that, you might have to get another driveshaft (longer / shorter). I used a 3speed with overdrive and I didn't have to touch the driveshaft.
Old Jan 2, 2005 | 01:32 PM
SSCX2's Avatar
SSCX2
Not to Hijack the thread but Ive heard it is a PITA to swap to a 5 speed. Why is this? I eventually will swap my AOD for a manual and would rather have a 5 speed. Also I heard that the WC T5 from a stang is nearly impossible to use since the shifter sits too far back.
Old Jan 2, 2005 | 05:25 PM
bremen242's Avatar
bremen242
the T5's aren't really strong enough since our trucks weigh a lot more, and you can't use them with a xfer case. plus, it would be a serious PITA to adapt the clutch system.. (cable vs hydro).
The 5 speed is a pain because you have to use the concentric slave, which means changing the master to the newer slave. I don't think it would be hard, but it wouldn't be worth it just to swap in a M5OD. It would be if you were going the ZF5 route.
ocbp1981
15
Aug 3, 2016 12:24 PM
jdigio1960
Mar 2, 2011 09:41 PM
BuiltToughF250
82
May 1, 2004 04:22 PM
Racerdave
Mar 24, 2003 03:02 PM
billyb
May 1, 2001 08:41 PM
