Gem?
Old Jan 1, 2005 | 10:15 AM
everything's Avatar
everything
Gem?
I have a 99-F350 diesel. My turn signals works some times and doesn’t work other times. I will wiggle the fuse panel and it will work for a short time. A Lose connector I was thinking so I took out the panel and there is a black box hooked to the back of it. I think the problem is in that but I can’t get it open. Also my dome light stays on every now and then and will come on and off when I drive. I hear a clicking from that black box behind the fuse panel do I have to replace the hole thing I cant find one in the salvage yard and I see big $$$ can it be sent out for repair?
Old Jan 1, 2005 | 01:59 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 1, 2005 | 07:44 PM
Franklin2's Avatar
Franklin2
Do you see any corrosion and dampness back there? Ford had a problem in certain years with windshield leaks. The water runs right down in the GEM module as well as the fuse box. The whole thing gets corroded and all kinds of weird things start to happen. If you do a search on gem or windshield leak in this forum, you might find some older posts, one of which had a guy who took his whole fuse box apart and cleaned it up and put it back together.
websurfer
19
Feb 21, 2024 06:19 PM
07EXPYEL
Jun 7, 2016 11:51 AM
lakerats
Mar 17, 2011 02:40 PM
lakerats
Electrical Systems/Wiring
Dec 8, 2010 08:00 AM
Phil Mein
2004 - 2008 F150
May 9, 2010 06:16 AM
