97 Explorer wiring
Old Dec 31, 2004 | 12:30 PM
maverick302's Avatar
maverick302
97 Explorer wiring
I have a 97 explorer with the control trac 4x4 that is stuck part way in 4wdr when I unplug the wiring harrness to the transfer case motor everything is ok. If someone can get me a wiring diagram to the transfer case or any other sudgestions that would be great.
Old Dec 31, 2004 | 06:16 PM
Franklin2's Avatar
Franklin2
You can try a Haynes manual for a diagram, or you can get the diagram from www.helminc.com.
My Haynes for f150's has the pushbutton 4wd in it, but I don't know if it's the same as your explorer. Also have a co-worker that has a Ford ranger with the pushbutton 4x4, and he ended up buying a diagram from helm.
This is what little I know. You have the pushbutton control panel, and brain box mounted somewhere that controls the whole system. Your motor that is mounted to the transfer case has a large plastic part that has a position switch. This position switch tells the brain box where the motor is positioned. A lot of the time, something happens to the motor and it's brushes, an it just quits. Some people have been able to take them apart to fix them. Unfortunately the co-workers system kept blowing fuses. He found road splash had corroded a connector on the inner fender in the engine compartment, and that was blowing the fuses to the system. By the way, you may want to check all your fuses too. Even though you are getting lights, I think there are several fuses to this system.
rlester
Sep 17, 2013 10:07 PM
kseriesshifter
16
Jun 5, 2012 05:10 PM
johnnym0056
Feb 28, 2012 06:26 PM
bigjohnsonross
Feb 23, 2009 01:23 PM
