Using Spare With Oversized Tires
Old Dec 31, 2004 | 12:23 PM
NY-Ford-Lifer's Avatar
NY-Ford-Lifer
Question Using Spare With Oversized Tires
Is it harmful to drive with the factory spare tire when I've upgraded to oversized (approx. 33") tires? I do have the limited-slip differential in the rear. Had this thought while doing some highway driving this past holiday.
Old Dec 31, 2004 | 12:40 PM
InboundFX4's Avatar
InboundFX4
I sure wouldn't try it. Two different size tires spinning at different speeds. Sounds like a lot of stress on the differential. But you bring up a good point. What do you do when an over-sized tire goes flat? So I called Les Schwab. They suggested getting an over-sized spare. But they also said you should be okay driving to the nearest tire place.
Old Dec 31, 2004 | 12:44 PM
2004 Screw's Avatar
2004 Screw
You would be OK if just the front tire had to be changed and if your rear tire did go flat i would just take one of the front stick it on the rear put your spare up front done
Old Dec 31, 2004 | 05:34 PM
High Cotton's Avatar
High Cotton
You shouldn't have any problems if you use it long enough to get the flat fixed. I've done it before no problems.......
Old Jan 1, 2005 | 08:19 AM
YOMAN's Avatar
YOMAN
Or....
Put some more air in spare tire as close as max...to give some little gain of height then air down all 3 other tire to make it almost equal (height) then drive SLOW to some local to fix a flat tire or replace
Like all 3 (33") tires 25 psi and spare tire 40 psi something like that..
YOMAN!
Rose Clifford
May 14, 2011 03:24 AM
Scooter429
Feb 13, 2009 09:09 AM
FLstraycat2001
Jan 4, 2008 10:50 PM
MrNuckelhead
Jul 21, 2007 08:14 AM
4x06
Dec 8, 2006 08:39 AM
