First 300
Old Dec 31, 2004 | 12:07 AM
PowerbyFord's Avatar
PowerbyFord
First 300
I am working on my first inline six, and have a couple of questions. The engine is a 95 model EFI 4.9 . I am replacing the timming gears, and was wondering if there is suppose to be a bolt that holds the larger cam gear on? It has a threaded hole, but no bolt. I am use to V8's, which have a bolt to hold them on. Also, is there any certian way to remove the gears, I do not want to tear any thing up removing them. Thanks in advance, and I am glad to finally have one of these great engines.
Old Dec 31, 2004 | 03:08 AM
srercrcr's Avatar
srercrcr
If someone doesn't respond, search on this forum about the nylon cam gears.
Old Dec 31, 2004 | 10:45 AM
larry derouin's Avatar
larry derouin
the threaded hole in the Cam is to PRESS ON the gear to the cam. There is no bolt to hold the gear on as it's a press fit.
Larry
