4x4 doesn't work
Old Dec 30, 2004 | 08:52 PM
ohiof150nut's Avatar
ohiof150nut
4x4 doesn't work
hi my first post i just bought a 78 f150 4x4 and you lock in the hubs then put it in 4 wheel high it shifts into gear you can feel it and hear it but the front tires wont spin can someone help me please p.s everyone have a safe and happy newyear
Old Dec 30, 2004 | 09:25 PM
Ervin's Avatar
Ervin
HI I have a 78. It had a bad hub. If you have one bad hub you will not get the tires to spin. If you can get it off the ground you can check to see if the drive train is turning. or put it in gear and jack one front tire at a time to see if the hubs are locked up. Hope this helps. Erv
Old Dec 30, 2004 | 09:30 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Dec 30, 2004 | 09:33 PM
buzzbait65's Avatar
buzzbait65
with the hubs locked in shift it back into two wheel drive, then with the truck NOT running , reach inside the steering knuckle inside the front wheels and see if you can rotate the axle, it should be locked in place, if it spins then that hub should be checked on that side.....that is the easy thing to check. but it could be broken gears, broken axle (inner or outer) hopefully just a dirty or even an over greased hub....good luck
Old Dec 31, 2004 | 08:45 PM
ST_Wilson's Avatar
ST_Wilson
If it has the stock ford locking hubs on it save yourself some aggravation and buy a set of the warn hubs. I used to have to rebuild my ford hubs every summer. you'd lock the hub but because of the backwards design they suffered from you'd get no four wheel drive. I had to open the hubs out on the beach a couple of times to "manually engage" them... Enjoy the truck, Ford did a much better job with the rest of it, I just never liked those hubs
jwhitetail
2009 - 2014 F150
May 14, 2012 11:00 AM
bucephalus
May 13, 2012 10:53 AM
KawiRider78
May 7, 2011 12:30 PM
jmoats91
Jun 3, 2008 07:20 PM
sacf250
Offroad & 4x4
Dec 7, 2004 06:29 PM
