Sponsored by: Real Truck
Dana 135 diff on F-550
Old Dec 30, 2004 | 08:32 PM
jasonh's Avatar
jasonh
Question Dana 135 diff on F-550
I'm looking at buying an F550 with a Dana 135 differential that currently has 4.88:1 ratio. I would like to change them to 4.10:1 if I buy the pick-up. Ford dealer says that ratio is not available but Dana website shows otherwise. Does anyone know if 410s can be put in?
Thx
Old Dec 30, 2004 | 08:58 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Thx
Don't have any personal experience with this, but call around to some of the medium/heavy duty truck shops in your area. They will most likely be able to assist you.
As for changing them, you might also look into a secondary overdrive unit, such as the GearVendors unit, if you want a taller gear. This will enable you to run a taller gear, with the lower gear available at the press of a button, in case you ever need it.
Old Dec 30, 2004 | 09:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Thx
Welcome to the only family Ford Truck site, on the net. As you can see ...the members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Dec 31, 2004 | 01:30 AM
SoCalDesertRider's Avatar
SoCalDesertRider
The 4.10's are probably available from Dana for the Dana 135 axle, but you lose the heavy towing capability of the truck by switching the ratio. I agree with PSD60LFX4 about adding an aftermarket OD/gear splitter unit for double ovedrive instead of changing the ratio. Check out www.gearvendors.com and www.usgear.com. You also get the benefit of half-step gearing between each regular tranny gear which keeps the engine right in it's powerband in every gear for pulling really heavy loads. The Gear Vendors is rated to 26K GCWR and 19K GVWR, same as the F550 is rated.
If you really want the 4.10's, most axle/driveline shops can order Dana/Spicer gear sets. I got Dana/Spicer 4.56's for my Dana 60 from a local shop when I had my gear change done.
Old Jan 1, 2005 | 11:04 PM
Dean M's Avatar
Dean M
I would recommend you call Randy's Ring and Pinion. They have good selection and prices. I just regeared a Dana 80 with a rare 3.54 gear. Randy had them in stock. No one else did.
http://www.ringpinion.com/
I don't know if they will have the parts you need but it is worth the call.
Dean
Jonathan McManus
Nov 27, 2016 08:19 PM
delta charlie
Jul 18, 2016 07:16 AM
Ace!
May 7, 2016 11:59 PM
F350SuperCab4x4
Oct 2, 2015 07:07 PM
scarey1
Ford Truck Parts for Sale
Sep 14, 2015 10:41 PM
