pcv valve help
Old Dec 30, 2004 | 06:13 PM
f-4x4's Avatar
f-4x4
pcv valve help
can some one explain to me how to keep the pcv valve with a aftermarket 4 barrel intake.
thanks for any and all help
Old Dec 30, 2004 | 06:24 PM
f-4x4's Avatar
f-4x4
ps. do i even need the pcv valve or can i just put a breather in its place.
Old Dec 30, 2004 | 08:32 PM
95 F150's Avatar
95 F150
I ran a breather cap in the valve cover on my aftermarket 4 barrel intake with no problems, you should be okay going that route.
Old Dec 30, 2004 | 11:02 PM
stephenw's Avatar
stephenw
The PCV valve stands for "positive" crankcase ventilation, that is, it causes a measured amount of air to be drawn thru the engine to carry off condensation and blowby gases. That's a very good thing for keeping your engine clean(er) and dry(er). You could get a carb spacer with a built-in port for your PCV system, or likely your carb has a port that you could tap into?
Old Dec 31, 2004 | 02:21 AM
Torque1st's Avatar
Torque1st
Posting Legend
Most carbs have a large port on the back side that is specifically made for the PCV line. If you disable the PCV your engine will rapidly sludge up inside. Before the PCV they had road draft tubes to draw air thru the engine. If no air is drawn thru the engine or you just use breathers you will have a real mess...
Old Dec 31, 2004 | 09:02 AM
f-4x4's Avatar
f-4x4
thanks that helps alot. i dont know why but that was what is was most worried about on my 400 build up. thanks again
edward r
Jul 21, 2009 10:51 PM
jack manning
2004 - 2008 F150
Dec 22, 2008 02:08 PM
jlabrecquevt
1983 - 2012 Ranger & B-Series
Dec 3, 2008 08:31 PM
khadma
3.8 & 4.2L V6
Oct 16, 2008 08:53 AM
rth1
Mar 9, 2005 02:21 PM
