1978 - 1996 Big Bronco
92 oil pan replacement
Old Dec 30, 2004 | 09:29 AM
don muirheid's Avatar
don muirheid
Lightbulb 92 oil pan replacement
Hello!
Have a 92 bronco 5.8 EFI with auto 4x4 electronic
Oil Pan has rusted out across the back next to the exhaust crossover.
Plan to replace it this weekend.
I have an engine host.
Before I start I though I ask.
I plan to free the engine & trans from it's mounts and lift the engine up into the firewall.
Is this the way to go?
Old Dec 31, 2004 | 02:33 PM
Trucky18's Avatar
Trucky18
you dont need to remove the trans unless you dont want to unbolt the exhuats (which you will have to do to lift the engine) just jack it up untill the upper intake hits the fire wall, its tight but it will fit, thats how i did it a little bit ago...pics on superford
Old Dec 31, 2004 | 03:30 PM
don muirheid
tHANKS
WILL LOOK AT PICS
DON
