1950 Ford Power Steering Pump
Old Dec 30, 2004 | 06:56 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Ok, I am going to have to explore the electric route off line and see what I can find. What about the Toyota conversion where do you mmount the power steering pump on a 226 flat 6?
Old May 16, 2005 | 09:11 PM
51ford fan's Avatar
51ford fan
What did you find out ???
Old May 16, 2005 | 09:26 PM
Christopher2
Veteran: Navy
Nothing yet, busy working on other problems that are keeping the truck off the road. I am also working on getting the 254 6 cylinder just down the road. I think I am going to pick it up this weekend. Great another project, out comes the 226 in goes the 254. With dual carbs,dual exhaust and an electronic ignition.
Old May 17, 2005 | 03:15 PM
AXracer's Avatar
AXracer
I doubt anyone makes a PS pump mount for this application, but a little creative engineering should be able to produce a suitable mount from various mounting brackets and adjusters. Be sure the belt contacts at least 1/3 of the pulley or more and the pump turns in the proper direction. I'd get the mount that was for the pump you choose and see what is needed to mount it to your engine with the pulleys lining up. Make sure it's sturdy and allows for tension adjustment a PS pump strains a lot at full steering lock. You'll also need to make sure the pulleys are for the same width belt.
A machine shop ought to be able to adapt the right width pulley to the pump.
Old May 17, 2005 | 03:54 PM
Christopher2
Veteran: Navy
I have some literature on using electric pumps I gathered off the net. Most likely a Toyota or Subaru unit with a Toyota steering box.
Old May 17, 2005 | 04:53 PM
Randy Jack's Avatar
Randy Jack
Chris -
I am looking to use an electric pump with a Mustang II IFS. Can you give me the links (or copies of) the literature for those pumps?
Thanks
Old May 17, 2005 | 05:46 PM
51ford fan's Avatar
51ford fan
Chris, have you looked at the electric pumps on Ebay. I was looking at them awhile back, they had quite a few.
Old May 18, 2005 | 02:29 PM
MIKE SIRR's Avatar
MIKE SIRR
Electric Pump
I had the same issue on my flathead v-8. I asked a few months ago and someone gave me this link.
www.classicperform.com
HILLBILLY BOB
Apr 11, 2013 06:11 PM
ROCKY1956
Feb 4, 2011 07:18 AM
rpol7966
Mar 14, 2009 07:50 PM
oldguy829
Mar 11, 2009 07:43 PM
jaye
Sep 28, 2008 10:03 AM
