Computer Chips & Tuners
is a chip what i need
Old Dec 30, 2004 | 12:25 AM
ncr's Avatar
ncr
i have a 94 f150 302,aode trans 135000 miles i have got the shutter in my trans and i was wanting to know if a chip would help by reprograming the shift points.the extra torque would help alot also because it is a everday work truck that i tow trailers often.does anyone out there have any advice on chips or tuning tricks thanks
Old Dec 30, 2004 | 02:26 AM
Rancheroracer's Avatar
Rancheroracer
How old is your atf? If quite a few miles, try changing it first.
Old Dec 30, 2004 | 06:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE
Old Dec 30, 2004 | 09:56 AM
ncr's Avatar
ncr
it has about 25000 miles, due for a change .the trans done it the first time with 36000 on truck. i have run mobil 1 atf since then.changed at 60,85,110. it seems to start the shutter close to fluid change . do you think messing with any of the chips is worth it .
Old Dec 30, 2004 | 03:38 PM
FTE Ken's Avatar
FTE Ken
A chip will not program the AOD. You need an electronically controlled tranny.
Old Dec 30, 2004 | 07:16 PM
Rancheroracer
trans shudder
Yes, I would change it, if no obvious problems with tranny, put a Transgo shift kit in it. I put one in my 250 & very satisfied. Different levels of "firmness" supplied with the kit. It was easy to install also. Good time to do it when the pan is off. It will firm up your shifts! Check with Motorhaven on this site, they may have a kit.
Old Jan 2, 2005 | 08:00 AM
ncr's Avatar
ncr
thanks for all the advice, i will try the shift kit and let you know in a couple of days. thanks again
Old Jan 10, 2005 | 02:09 AM
TexasGuy001's Avatar
TexasGuy001
You could also try the AODE transmission shutter fix from Auto Trans. Its a little circuit board that you mount inside the bottom of your transmission. It splices into a couple wires that run to a solenoid. It is specifically designed to aleviate this common problem with the 4R70W. I have one one my truck. I installed it about 4-5 years ago. I think it works great. The truck has shifted better ever since. It firms up the shifts. I think it costs about 75 bucks. I'm not sure where you can get one. I got mine from a local guy who rebuilds transmissions. You might be able to purchase one off of their website. The cool think is you can install one of these while your servicing your tranny.
KonaGrown
17
Aug 31, 2011 10:46 PM
640 CI Aluminum FORD
Apr 23, 2011 04:55 AM
jrciii56
15
Mar 2, 2008 04:19 PM
kellar
Oct 11, 2006 05:53 PM
89XLTBronco
Apr 9, 2002 10:26 PM
