Bronco II Ford Bronco II
Back Firing
Old Dec 29, 2004 | 11:19 PM
slimbronco's Avatar
slimbronco
Back Firing
Ok I have a 84 B2 with the 2.8L engine I have a holley carb. I just started having back firing issues with the bronco. It doesn't do it all the time only sometimes when I start the B2 and sometimes after coming to a stop and start driving again it will back fire does any one have any suggestions?
Old Dec 30, 2004 | 10:09 AM
wicky's Avatar
wicky
I've got the same problem too, as well as back firing thru the intake@ the same time, although mine's a 2.9 w/ EFI. Slimbronco, does it "bog/sputter" when it back fires when you put your foot in it too?
Old Dec 30, 2004 | 11:41 AM
slimbronco's Avatar
slimbronco
Yep it does just that and then it kicks out of it and goes on with life until the next time
Old Dec 30, 2004 | 02:38 PM
87 XLT's Avatar
87 XLT
Hows the ignition timing, if it's retarded it will backfire.
If you watch it running in the dark is there any crossfirng between plug wires. Is the distributror cap in good shape?
