p1729 low 4x4 error code
Old Dec 29, 2004 | 08:56 PM
Rooikat's Avatar
Rooikat
I know the OBDII code def. gives several different scenarios for this code= eg. bad circuit/pcm or faulty switch. Problem only present in open loop status, once warm no problem. Has anybody encountered this before and what was the solution?
Thx
Rooikat
Old Dec 30, 2004 | 12:06 AM
Racerguy's Avatar
Racerguy
That's an interesting one.
How do you know that the problem is only there in open loop?
I assume you're not in 4low when doing the test?
Old Dec 30, 2004 | 03:58 PM
Rooikat's Avatar
Rooikat
The vehicle is in 2x4 and the symptoms seems persistent while the vehicle is cold. I ran a Auto x-ray scanner on the truck when it was doing this and it seems to be during open loop status. The truck has some modifications but that does not relate to this specific code unless there is a possible grounding issue with the electrical.
Old Dec 30, 2004 | 09:38 PM
Racerguy's Avatar
Racerguy
Do you have a manual with the pinpoint tests to go through?
Old Dec 31, 2004 | 11:34 AM
Rooikat's Avatar
Rooikat
The code is trans/drivetrain specific but I have a suspiscion that the problem may be with the pcm because the truck also surges and idles irratic when cold as though the pcm may have a ground fault somewhere. I am told that either the pcm works or it doesn't and the truck runs fine after it is warm? The haynes manual is either not specific or I do not have the tools so I will take it to a custom shop in the new year.
Happy New Year!
Rooikat
bryanrandall
Jan 19, 2017 07:00 AM
griggssteve
2004 - 2008 F150
Jan 10, 2017 07:32 AM
clark714x4
22
Apr 21, 2004 07:47 PM
la9
1997 - 2003 F150
Aug 7, 2003 02:33 PM
Miketnf150
1978 - 1996 Big Bronco
Aug 21, 2002 12:57 PM
