delo 0w30
Old Dec 29, 2004 | 03:46 PM
mybigredford's Avatar
mybigredford
delo 0w30
i just bought some delo 400 0w30 today, is this the right stuff for my 02 PSD
Old Dec 29, 2004 | 04:47 PM
mjwhip2's Avatar
mjwhip2
According to chevrons PDS:
Chevron Delo 400 Synthetic heavy duty motor oils meet:
• API Service Categories
— CG-4, CF-4, CF, CD1, SH1, SJ
— Energy Conserving for API SH1 (SAE 0W-30)
— CI-4 PLUS, CI-4, CH-4, SL (SAE 5W-40)
So in other words: Yes
Old Dec 29, 2004 | 05:13 PM
ColtM4's Avatar
ColtM4
where did you get 0-30? And to answer your question, probably too thin unless you are in really cold area. I'd just like to thin down 15-40 for the winter with a mix.
Old Dec 29, 2004 | 06:31 PM
mybigredford
i got the 0-30 at the chevron cardlock where i get my fuel. i can tell you that it get cold where i live, it can range anywhere from 34 all the way to -25, my buddy is running 0-30 right now, but he works in the bush. i heard that if i run 0-30 that i shouldnt go on a long trip with it in there, what do you guys think? anyways with the temp range i gave you do you think i should run the 0-30?
Old Dec 29, 2004 | 07:36 PM
Flash's Avatar
Flash
The Delo that you have is one of the finest oils made today. Its rating of CH-4+ in the Chevron line means it is a synthetic blend (GpIII and Gp II) with about 125 ppms of moly. You can run this oil anytime, not just winter. Remember that when the engine and oil are at temp, it has the lube qualities of a 30 viscosity oil. Frankly, where you live, there isn't a better oil.
Old Dec 30, 2004 | 12:24 AM
ColtM4's Avatar
ColtM4
I think I agree with Flash, where you live, there probably isn't much better than that. How much a gallon?
Old Dec 30, 2004 | 02:21 PM
mybigredford
i am not too sure how much a gallon it was they just put it on my account and the bills go to my secretary to pay, i will check into it for you. so it is ok to run the 0-30 with no problems and i can go on say an 8 hour long trip with no problems?
in the summer i will put the 15-40 in though
Melchiah
Oil & Lubrication
Sep 25, 2007 07:36 PM
Dustin_86
Oil & Lubrication
Apr 4, 2005 02:43 PM
montanacw
Oct 5, 2004 07:33 PM
John with beastly 302
Oil & Lubrication
May 20, 2003 05:45 PM
