Oil & Lubrication
Super Tech VS delo400
Old Jan 8, 2005 | 10:38 PM
Dustin_86's Avatar
Dustin_86
Question Super Tech VS delo400
I was thinking about switching from Castrol GTX 10w30 to Super Tech FULL synthetic 10w-30-How good is this stuff.How does it compare to castrol GTX?
How does the tech syn compare to Delo 15-40 in the summer?is it bad to switch to castrol GTX from delo during the winter and then back to delo because I can't find 10w-30 delo.
The truck this concerns is my 86 F150 EFI 302 ext cab lB that does NOT use any oil but seeps out a little but no leaks.In other words 5K changes and the oil level is still RIGHT on the full mark
Old Jan 9, 2005 | 11:32 AM
seldont's Avatar
seldont
If you are using Castrol and doing 5000 miles changes woith no consumption what are you trying to accomplish by switching?? Personally I would either use a good 10w30 (Chevron,Havoline,Motorcraft,Pennzoil,Castrol) or just use the Delo instead of using the Super Tech synthetic. It is most likely a group III synthetic at best anyway. If you really want to use a full synthetic just go buy the Mobil1 at Wally World. My .02 ...........
Old Jan 9, 2005 | 06:14 PM
FERacing66's Avatar
FERacing66
According to Flash, wear metals go up with syns in cold weather and cold starting conditions. Something to think about. I myself run Mystic, a little hard to get but its cheap and is disel rated, disel rated oils are far supeior to SL rated oils becasue they have more detergents and a better additive package.
Old Jan 9, 2005 | 10:22 PM
ford390gashog's Avatar
ford390gashog
yes but most diesel oils are dual rated cl-4 and sl rotella is a good oil too
Old Mar 27, 2005 | 02:09 AM
kopfenjager's Avatar
kopfenjager
isn't a clas III syn still better than a coventional dino oil?
Old Mar 27, 2005 | 07:56 AM
MBDiagMan's Avatar
MBDiagMan
For your earlier engine, IF you are not in a cold climate, I think Delo 15 40 is a great choice. I've run it in everything on my place that does not have roller lifters for about 20 years with fabulous success.
Best of luck,
Doc
Old Mar 27, 2005 | 09:45 AM
BlueRanger94's Avatar
BlueRanger94
Why change if your 86 is running so well on what you have been feeding it. The only change I would make is trying Castrol high mileage oil to see if it lessens the slight seepage.
Old Apr 4, 2005 | 02:43 PM
jimandmandy's Avatar
jimandmandy
GTX will be API SM now or soon and will have a reduction in ZDDP. With a flat-tappet cam, a diesel-rated oil may be an advantage. Your profile states TX, so 15W-40 is fine all year (down to +4F). I'm trying 10W-30 Chevron Supreme in the '94 (roller cam) now, but no increase in fuel mileage over 15W-40 and it uses a little more.
Jim
Restlesswildman
Sep 1, 2013 04:58 PM
russ&irene
Oil & Lubrication
35
Dec 10, 2011 11:13 AM
zillah
Oil & Lubrication
Jan 23, 2009 09:17 PM
Dustin_86
Oil & Lubrication
34
Jun 21, 2006 08:41 PM
rgiles
Oil & Lubrication
Jun 27, 2005 09:41 PM
