Bronco II Ford Bronco II
No ignition fire
Old Dec 29, 2004 | 12:08 PM
rog123's Avatar
rog123
No ignition fire
Hello, I have a B2 2.8l 1984 and last day it stalled and when I tried to start the engine, it won't start again. So I remove the ignition cable from the distributor cap and I insert a screwdriver end in the cable and I get no sparks from it when it's close from the ground body. I thought it was the ignition coil who was defective so I replace it with new one---same problem. I checked the voltage at the terminals connectors on the coil and I get 12 volts when I turn the ignition on. Do you have any solutions.
Old Dec 29, 2004 | 02:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE
