Sponsored by: Kumho
Rear 6" higher than front
Old Dec 29, 2004 | 12:02 PM
cookch1's Avatar
cookch1
I have a 1987 2wd F150 with an inline 6. The difference in height (front to back) at the wheels is 6". The rear has a helper leaf in it that is about 1/2" thick. I'm looking for the cheapest way to level the truck without messing too many things up. A guy at a suspension shop says that the helper leaf will only raise the vehicle the thickness of the leaf. He says he could de-arch the leafs and correct the problem for about $150. I figure I would keep the rear about 2 inches higher since that seems to be the way Ford sends them off. So, should I raise the front only, raise front and lower back, or lower back only? I would like to do as much of the work myself to save some money. Spacers? Lift kit? Lowering kit? De-arch? By the way, how the heck did my truck get 6" higher in the back anyway? Any help is appreciated.
Old Dec 29, 2004 | 12:44 PM
Hourang's Avatar
Hourang
does it have blocks in the back?
Old Dec 29, 2004 | 01:02 PM
cookch1's Avatar
cookch1
It doesn't look like it has blocks. All that is there is the bracket that holds the center pin.
Old Dec 29, 2004 | 01:38 PM
racsan's Avatar
racsan
id lift the front with leveling springs, if you dont use it to haul much you could put in a lower weight rating spring pack, but id hate to take away from a good suspension. sounds like a pevious owner put in more suspension for hauling. i have a friend who has a '91 1/2 ton s/c 2wd with a massive spring pack but it doesnt seem too high in the rear, im sure it isnt "stock"
jdebusk
Dec 19, 2014 08:23 AM
Pappys53
16
Oct 13, 2011 03:18 PM
bman50
2004 - 2008 F150
Jan 12, 2010 06:58 AM
cbsaf
2004 - 2008 F150
Jan 9, 2005 09:27 AM
Grumpy Gramps
18
Oct 12, 2004 06:05 PM
