Front axle question
Old Dec 29, 2004 | 09:38 AM
galaxy5oo's Avatar
galaxy5oo
Front axle question
I have a 51 F1 1/2 ton that I am wanting to lower within a budget. On the front axle I have been reading and it looks like the best option is sending it to one of the places that will modify it to have a drop. I was wondering though. A friend of mine that is pretty knowledgable about older cars and trucks says he thinks that the 3/4 ton ford pickups in the 48-52 range had a different front axle than the 1/2 tons that had about a 4 inch drop. I have looked all over to try to find info out on this and I have never found anything about it. I am thinking it is probably the same axle as the 1/2 ton, but I wondered if anyone on here could tell me for sure. Thanks
Old Dec 29, 2004 | 12:50 PM
barry's Avatar
barry
THe axle is exactly the same on the F-1, F-2, F-3 models for 48-52. They use the same spindles also. It's the backing plates and brake parts that make the difference in the different models.
Barry
50 F-1
Old Dec 29, 2004 | 01:04 PM
galaxy5oo's Avatar
galaxy5oo
Thanks for clarifying, I thought I would have seen some mention somewhere of this as much as I have been researching it lately. Figured I could not get that lucky and out that cheaply. lol
Old Dec 29, 2004 | 04:17 PM
six7seta's Avatar
six7seta
they are the same except the leafs are diffrent, and the f2 and up ususally came with an 8 bolt patter hub. you can get a brand new one from midfifty thats been dropped 3" or 4", and its probaly safter then having one modified
Old Dec 30, 2004 | 08:33 AM
galaxy5oo's Avatar
galaxy5oo
Thanks six7
Old Dec 30, 2004 | 09:53 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
There are several companies that have the front axle Classic performance products has it also. I would Like to find out what they build the axles to for specification both camber and caster. The Heat and bend dropped axle does have one advantage if you want a deeper wheel, the front axle is 1.5" narrower.
