Timing Gear Problem
Old Dec 29, 2004 | 09:35 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about engines; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE
Old Dec 29, 2004 | 08:20 PM
true4.2's Avatar
true4.2
Man that sucks. You seem like you know quite a bit about engine work, and that brings me to my point. It seems like you've figured out the problem, but how much (and I haven't looked myself 'cause I'm lazy) is a new sprocket and key? If it's not much I'd say go that route and see if it happens again. If it does you definately know what the problem is, and I'd bet you'd have to replace/swap some parts to get it fixed.
