Problems getting NAPA filter MOD on
Old Dec 28, 2004 | 10:24 PM
Robbgt's Avatar
Robbgt
Question Problems getting NAPA filter MOD on
O.K., so i ran out and bought a NAPA 6637 filter for my 97, and i'm having difficulty setting it up. Right now, i have it connceted directly up to the stock hose, but it seams too short, and it is very close to the hood, and the master cylender. I have heard or people using a piece of PVC, like 22* piece and puting it between the stock hose, and the filter, but how will they seal correctly? if both pieces are solid plastic?? any help would be great, thanks- Robb
Old Dec 28, 2004 | 10:30 PM
mech2161's Avatar
mech2161
Is your air duct to the turbo rubber? I've heard of useing a 4 inch piece between the filter and the original tube,
Old Dec 28, 2004 | 10:31 PM
ltfox's Avatar
ltfox
I think most have used a 4" peice of exhaust pipe to go between the black hase and the filter. Pvc might work also. It helps if the pipe is bent 45 deg. It should sit right where the stock box was.
Old Dec 28, 2004 | 10:33 PM
Robbgt's Avatar
Robbgt
yea its goes Rubber (red) off the turbo - Metal (grey) where CCV pipe is located - Rubber (black) that ran to the original filter box..... i'm not sure how other people got the pipe to stay secured onto the new filter because they are both a hard plastic.... thanks.... ITfox, does the hard plastic-hard plastic seal??-thanks
Old Dec 28, 2004 | 10:36 PM
mech2161's Avatar
mech2161
The rubber tube that connected to the air box will stretch over the filter, then install the original clamp.
Old Dec 28, 2004 | 10:39 PM
Robbgt's Avatar
Robbgt
mech, i tryed that, unfortunately i have a 97, and the hose is not long enough to reach all the way into the bay where that factory box was, and i don't like the idea of it being pinched between the master cyl. and the battery, and the hood.... a little to close for comfort.... Just wondering if anyone has tryed/used a pvc fitting in there.... thanks for the help so far mech
Old Dec 28, 2004 | 10:41 PM
mjwhip2's Avatar
mjwhip2
Robhere is what I did. I used a piece of 4in exhaust pipe 45 degree angle.
Piece of cake,
Mike
Old Dec 28, 2004 | 10:44 PM
Robbgt's Avatar
Robbgt
Piece of cake,
Mike
Ah, thank you sir!! Just the picture i was looking for..... how tight is the seal between the filter and the pipe?
Old Dec 28, 2004 | 10:48 PM
mjwhip2's Avatar
mjwhip2
Nothing is getting by there. You should hear that turbo howl. Sounds like a big rig on the freeway.
Mike
Old Dec 28, 2004 | 11:05 PM
ltfox's Avatar
ltfox
When I pushed the pipe and filter together I would'nt have thought you even needed a clamp. Its tight enough leakin is the last thing youll worry about. You'll love it!
Old Dec 28, 2004 | 11:27 PM
Robbgt's Avatar
Robbgt
Thanks guys.... Well it's 12* outside.... and it's 12:30 .... so i think i'll fix it in the mourning..... I'll let you know how it turns out+ take a few picks in the mournin'.... thanks again!
