transmission service
Old Dec 27, 2004 | 08:08 AM
ripdad's Avatar
ripdad
I have an early 99 F250 super duty 4x4 with 108k on it. I have had the trans. flushed twice before without removing the pan. I am taking it wed. to have the trans. serviced. After reading the threads here I think the trans. is the weakest part of this truck. I would like to have the pan pulled this time to change the filter and also thinking about putting an auxilliary cooler on it to cut down on the heat. I think I have the 4r100 trans. Can I switch to synthetic fluid this time or stay with regular? I enjoy this forum and thank you for your responses.
Old Dec 27, 2004 | 08:52 AM
Casey's Avatar
Casey
You do have a 4R100. You can switch to synthetic as long as you get a MERCON synthetic. Don't use a fluid that says MERCON V, or meets both MERCON and MERCON V. Your owner's manual says that you could have serious transmission damage if you use MERCON V. I use Mobil 1 synthetic ATF. It is MERCON rated, but not MERCON V.
Old Dec 27, 2004 | 06:59 PM
MobeyDick's Avatar
MobeyDick
I have to wonder were the Weak 4R100 tranny BS comes from!! I have 190,200 miles on mine and I have never had a single problem with it!! I didn't change the Fluid until 141,000 miles and only checked it 4 times durring that period!! I did switch to Mobil 1 Syn. at that time and I haven't checked it sense!!
Old Dec 27, 2004 | 07:54 PM
cangim's Avatar
cangim
Get a bigger heavier trailer, then get stupid and try pulling that block over mountanious hills at 75+mph, that'll probably start some of the "week 4r100 tranny BS"
It all boils down to how each individual drives.
Old Dec 27, 2004 | 08:00 PM
MobeyDick's Avatar
MobeyDick
Over the last 6,500 miles I've put over 2,000 on mobey pulling my 8x18x9'6" high 10,000# trailer!! Mobey knows it's back there!! Don't have any mountains to deal with but I do drive like hell!! Still never had a single problem!!
Old Dec 28, 2004 | 11:36 PM
KCBikerBoy's Avatar
KCBikerBoy
is the additional tranny cooler a good idea to lower temps?
