TFI Ignition replacement
Old Jan 12, 2005 | 09:02 AM
MRStace84's Avatar
MRStace84
The TFI on my 84 was nothing but a nightmare ever since we have owned that truck. Best mod I ever did was going to a Duraspark 2.
Old Jan 12, 2005 | 08:03 PM
insynco's Avatar
insynco
Oscar,
My engine has a hard time heating up with this stock manifold using the exhaust heat cowl. In the winter it is a problem. You have to wait a good 20 or 30 minutes for it to heat up so it wont cut out. That is why I am interested in a better heating intake and I am trying to visualize how this clifford heated mainfold works. I checked the Clifford website and the manifolds listed do not indicate whether they are heated. Do you have a part # for the one you used? I am assuming you are using the 2v (2 bbl).
I think the reason for the lack of heating is this split manifold design, a real blunder in my opinion. Is this Clifford A split design or is it all one peice, (Intake and exhaust?) How does it heat the intake any better than the stock manifold?
Old Jan 13, 2005 | 07:35 AM
Oscar Meier's Avatar
Oscar Meier
The Clifford design circulates heated water thru the body of the manifold to heat the entire intake including the carb.
The clifford is not a dual plane manifold it is a single plane (Open plenum) The clifford # has a 'H' at the end for heated.
Clifford also has the heated carb bases I mentioned above.
All of the manifolds you'll find for the 300 will be split design. The factory design is split. if you have a problem with heating on the factory set-up check your heat riser control in the top of the exhaust manifold connection to the bottom of the intake manifold. You may want to invest in a Chiltons or Haynes repair manual for better descriptions of these parts and repair.
