Auto Trans problem
Old Dec 28, 2004 | 07:59 PM
Adam K's Avatar
Adam K
Auto Trans problem
Well I just picked up this 88 ranger 2.9l 4X4 and it runs great shifts great, most of the time at least until I got it inspected today. Anyway it will drop in to reverse fine but it will not drop into any foward gear without revving the engine and even then it doesn't always drop in, but as long as it's moving it seems to shift okay. I was wondering if the vacuum modulator could be bad or if the trannys just shot.
Please Help
Adam
Old Dec 28, 2004 | 09:52 PM
hreed's Avatar
hreed
It's probably not the modulator. There should be a hose running to the modulator that you can check to make sure it is hooked up. How does the fluid look and is it full? Maybe a filter and fluid change will solve the problem. I have had good luck with a product called Sea Foam in transmissions. Try a can before doing major repairs.
Old Dec 28, 2004 | 11:27 PM
Adam K's Avatar
Adam K
Already change the fluid and screen but I will try that seafoam stuff and check the hose.
Thanks
Adam Wider
Nov 1, 2012 11:16 PM
Adam0331
19
Sep 18, 2008 09:53 PM
killaz
Dec 16, 2006 07:04 AM
adamkusler
Escape & Escape Hybrid
Nov 17, 2004 06:32 PM
Adam_C
N. California Chapter
Oct 5, 2004 10:42 AM
