Rear end tag id
Old Dec 28, 2004 | 07:23 PM
61 uni's Avatar
61 uni
Rear end tag id
Can someont tell me what all of these numbers mean?
WGB-G5 5KE
2.75 9 442D
This is from my 76 bird parts car.
Old Dec 28, 2004 | 08:08 PM
ecarter50's Avatar
ecarter50
9" Ford open differential with 2.75 gears. There would be a L in place of the decimal point like this 2L75 if it was limited slip.
Old Dec 29, 2004 | 06:59 PM
286merc's Avatar
286merc
The bible (Hollanders) says it was used in 73-5 Birds. It is a 28 spline unit with the 4 pinion gear setup.
Its a decent unit for using under a truck that doesnt run a big engine or gets beat on a lot. Even tho the Bird had a 460 those were early smoggers that were seriously detuned.
The HD axle uses 31 splines.
