I have 71 F250 that I have had since 72. Bought it with 18,000 miles on it. 360 w/4speed granny gear.
Going to update it, to 390, power steering & disc brakes.
Going to need help on these projects I'm sure.
I've had this truck to long to part with it, got to fix it up.
Looks like a great forum here!
I'll try and use the "Search" if I can find it.
Thanx
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE
Search ...is located accross the top blue banner with "UserCP" and "FAQ"....
Using search,
already found out how to wire in delay wiper switch from a 81 F250, into a 71 F250, I have swapped the blk/wht male pin into the empty space (for the washer) and it works.
Tommarrow I will file and cut down the shaft and install, if not raining to hard.
Thanx all
