Offroad & 4x4
tow hooks
Old Dec 28, 2004 | 06:15 PM
warrencowboy05's Avatar
warrencowboy05
tow hooks
im thinking of investing in a set of tow hooks because as of now i dont really have anywhere to connect a tow strap or anthing to save my ***. can i just hook them on to my bumper's or where is a good mounting spot. my front bumper is stock but ive got a different rear bumper on my truck
Old Dec 28, 2004 | 06:24 PM
racsan's Avatar
racsan
on the 3/4 ton i used to have i mounted them sideways on the bottom edges of the sides of the receiver hitch. you want to pick something solid like the frame or receiver or grille guard. you could pull the bolts right through the bumper under the right conditions and then have you ever got a deadly projectile. if you have front and rear receivers you might want to think about a drawbar with a clevis, seen it as part of a winch accesory kit or you could make your own.
Old Dec 28, 2004 | 06:28 PM
warrencowboy05
ok, ive got the hitch in the back so thats all set. then up front, ive got these two bars. one of the previous owners said that they used to tow the truck behind an rv. so the two bars were used to hook it up to the rv. would these be strong enough? i would think so but im not real sure
Old Dec 28, 2004 | 07:00 PM
racsan's Avatar
racsan
they might be, as long as they are mounted to the frame with at least grade 8 hardware you should be o.k. remember, if you're pulling (or being pulled) out of the mud (or snow) you have the vehicle weight plus the resistance of whatever you're stuck in. (like when your boot gets sunk in the mud and it's real hard to pull it out). better to be safe than to be a statistic! Dave.
Old Dec 28, 2004 | 07:35 PM
warrencowboy05
thanks dave
Old Dec 28, 2004 | 08:56 PM
teds74ford's Avatar
teds74ford
I used chevy tow hooks because they mount on the bottom of the frame so they are under the bumper. This way a strap or chain won't dent the bumper when you pull. Now, I have a front hitch and clevis. This way it pulls from both framerails. Here is a pic of the chevy tow hooks on the frame.
https://www.ford-trucks.com/user_gal...=25269&width=2
You can get them at any junkyard for cheap (lots of chevys )
Old Dec 28, 2004 | 09:18 PM
grafekie's Avatar
grafekie
You can always eBay up some factory hooks... I'll trust them over almost anything else, even a receiver as they aren't rated for that stress, and say it right there in the manual/box/safety stamp.
Old Dec 28, 2004 | 11:34 PM
Ryan50hrl's Avatar
Ryan50hrl
those chevy hooks have been known to snap...i really wanna get a set of hooks off the front of a dumptruck...those things are huge...
Old Dec 28, 2004 | 11:41 PM
ivanribic's Avatar
ivanribic
Seacharoo!!!! I even did it for you. Here's 3 good ones out of about 100 available.
https://www.ford-trucks.com/forums/s...d.php?t=287510
https://www.ford-trucks.com/forums/s...ad.php?t=78211
https://www.ford-trucks.com/forums/s...ad.php?t=77581
Old Dec 29, 2004 | 12:21 AM
racsan's Avatar
racsan
might look at some school buses at the local junkyards, ive noticed the bus dad drives has some massive tow hooks on it, front and rear.
Old Dec 29, 2004 | 05:46 PM
fishmanndotcom's Avatar
fishmanndotcom
hooks are way over rated and SUCK. get D-rings or shackles....they can't straighten out like i have seen tow hooks do!
look in my gallery for a pic of what a D-ring is and go here for what a shackle is http://www.rockstomper.com/catalog/r...y/shackles.htm
-cutts-
Old Dec 29, 2004 | 10:30 PM
fords_forlife's Avatar
fords_forlife
Ryan50hrl - I know what you mean with tow hooks off a dump truck, I recently got 4 of them out of a junkyard and they are huge must weight like 10 lbs each, they were off a 50's era ford dump truck
FORDS_FORLIFE
Old Dec 30, 2004 | 09:17 AM
brokebronco's Avatar
brokebronco
The superduties have some real nice hooks. I put two on the front of the Bronco alongside the frame. I need to cut slots in the bumper for them to poke through this weekend.
Chris
Old Dec 30, 2004 | 09:29 PM
rebocardo's Avatar
rebocardo
If you like heavy duty stuff and do not mind ordering through a dealer, may I suggest:
http://www.thehollandgroupinc.com
The catalog for pintle hooks (what I like to run for straps and such, even though I have tow hooks) is about 4 MB and gives all the dimensions for their excellent stuff.
Old Dec 30, 2004 | 11:37 PM
Ryan50hrl's Avatar
Ryan50hrl
I know what ya mean about those superduty loops...those are pretty darn tough....i wouldn't mind havin a set of those...
senix
Ford Truck Parts for Sale
Jun 19, 2016 08:44 AM
timellis
Jan 19, 2015 10:18 AM
Alec94F150XL
13
Jan 10, 2015 03:26 PM
Bruteskeg
Jan 9, 2014 01:26 PM
Buzzard_Wing
Offroad & 4x4
Jan 1, 2004 09:24 PM
