set up for high altitude
Old Dec 28, 2004 | 04:32 PM
why165's Avatar
why165
i am going on a very long trip that will take me over the 5000 foot mark. the question is what do i need to do before i go to set up the truck for such high altitude?? here in louisiana 500 feet is high. any tips or tricks would help greatly.
Old Dec 28, 2004 | 05:02 PM
PLC7.3's Avatar
PLC7.3
There is not much you can do really unless you want to change the IP. The engine will lack some power and smoke a but more. The worst performances come around 10,000', where your going 5000' is really not too bad. If you will be just going over high terrain, I usually just gear down and keep the revs up a bit. If you put your foot into it without gearing down you will see smoke thicker than you've seen before probably. If you have an automatic then the BARO will change the shift to be slightly harder so there is no slipping.
Old Dec 28, 2004 | 08:27 PM
fordfury469's Avatar
fordfury469
not much you really can do like plc said. higher in alt the less air you get see level the is 14 and like at 8000 feet you go like 8 psi or something like that so you loose alot of air going into the cylinders. only realy way to compensate is to have a turbo, super charger. thus cramming more air into cylinders.
Old Dec 28, 2004 | 09:12 PM
why165's Avatar
why165
the truck is a 94 idi turbo cc 350. i am towing a 33 foot 5th wheel. if there is nothing to do but live with it i gues that is the answer i was looking for.
Old Dec 28, 2004 | 09:29 PM
fordfury469
yeah you could always change your turbo housing for one with more boost, there always things to get more power out of one but it cost $$.
Old Dec 28, 2004 | 10:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
With the turbo you should have no problems at all with the power dropping off.
You will blow slightly more smoke taking off from a stop and the pyrometer may run a little higher than normal.
You should still be able to build the same boost you see at 500 feet.
Watch the tranny and coolant temps, the thinner air will not cool the radiators as well as the air you are used to. The winter season will be working to your advantage though.
Old Dec 29, 2004 | 09:49 AM
Birken Vogt's Avatar
Birken Vogt
With a non turbo you have to worry about overheating the pistons, and wasting fuel. Just watch the black smoke and if it starts to pour out, back out of the throttle some.
Turbos are mostly self-compensating but just the same you should always keep an eye to the tailpipe.
Birken
