Identity Crisis
Old Dec 28, 2004 | 03:33 PM
liv3wire's Avatar
liv3wire
Identity Crisis
Ok here goes everything I have found:
Under oil filter: 6A5 no more (..) under 6
Front of block casted: 105 or mirrored 501
Head
Valve covers have 5 bolts
Under valve cover: 5M15
Next to spark plug: D2TEAA
Circle next to plug: 1 9 7 5 3 in that order, "Wierd"?
Intake: D5TE-9425-K8
Could not find any numbers on the crank
Motor mounts are bolted on by 2 bolts, not covering any freeze plugs
Can someone decifer all this and tell me year and make of motor?
pistons are out so cant measure stroke.
Thank You
Todd
Old Dec 30, 2004 | 09:03 PM
jwtaylor's Avatar
jwtaylor
What letters/numbers on the block do you see where the starter would go, then a short code below that?
Old Jan 1, 2005 | 09:50 AM
liv3wire's Avatar
liv3wire
Need help Identity
found some more info:
jwtaylor... there were no numbers by where the starter goes. I have scraped and cleaned the block to where it is blue again.
bearings stamped:
main:
D.A.B
11-75 H PC
C8AE-6A338-A-B
FORD
rod:
D.A.B.
11-75 DD PC
C6AE-6211-S-T
FORD
are these the original bearings?
found on intake: 8C28
found on heads: 203
found on crank(from front to back): counter weight #1 - 33, #3 - 2TA on one side and 1 on other side.
piston diam.: is 4"
Somebody please help¡! Need year and size.
Todd
Old Jan 1, 2005 | 10:15 AM
jwtaylor's Avatar
jwtaylor
302/351w would have 6 valve cover bolts and a casting number near the starter location on the block...hmmm
Can you measure the stroke?
Try this link, it takes some looking over to find anything but maybe it would help:
http://aacncclub.com/
Any chance you could post some pictures?
Old Jan 1, 2005 | 10:23 AM
jwtaylor's Avatar
jwtaylor
This link has a simillar intake code, except where you have an "8" they use a "B".
https://www.ford-trucks.com/forums/a...x.php/t-130025
The 390 used a 4.005 bore according to that link.
Hope that helps
Old Jan 1, 2005 | 10:36 AM
liv3wire's Avatar
liv3wire
aauurrgghh
lI never knew identifying a motor was so difficult.
more accurate on cylinder measurements with tape of course would be 4 3/64ths
push rods: 9 1/2" no numbers
harmonic balancer: BTC D5TE-DA
I am measuring the pistons with a tape measure so it is difficult to get exact.
Yes I will be able to post pictures later, wife has dig cam and is out of town until tomorrow.
And i know it is either a 360 or 390. valve covers have 5 bolts.
Old Jan 1, 2005 | 11:01 AM
jwtaylor's Avatar
jwtaylor
C8 and C6 could mean 1968 or 1966
D5 could mean 1975
If you now its either a 360 or 390 then your not too far from knowing what it is, they both use the same bore but the stroke differs, thats easy enough to check:
360 ---- 3.50" stroke
390 ---- 3.78" stroke
Do the FE engines list the casting number for the heads on the bottom, on the SBF the casting number is on the bottom side of the head or under the intake port, that might get you closer to the year of the block.
Old Jan 1, 2005 | 11:03 AM
Icicle's Avatar
Icicle
do you have reason to believe it is not the original motor?
How about some info on the truck? what year is it?
Your valve cover bolt description matches that of an FE motor.......which makes it like you said, most likely a 360 or 390, if its a 70's truck, and a 4x4 I would bet 360.
Old Jan 1, 2005 | 11:08 AM
liv3wire's Avatar
liv3wire
It's a 1968 F100 4x4 automatic
Old Jan 10, 2005 | 04:44 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum for more information.
Old Jan 10, 2005 | 04:59 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
The date code 6A5 with two dots under the 6 means it's a 76/Jan/5th date code. The two dots under the first digit 6 represent a 70's block casting. I'm late for work so I can help more later tonight! G.
Old Jan 10, 2005 | 11:31 AM
Mike G's Avatar
Mike G
It's a rebuilt 360...
2TA is a 68 and newer 360 crank.
D2TEAA heads are 72 and newer heads with hardened seats.
D5TE on manifold is a 75 truck version.
Pistons are at 4.00 and I would guess your bore on the block is 4.05, unless there is a "030" or "060" on the top of the pistons...
--Mike
86f1504.9rookie
29
Oct 9, 2016 09:52 AM
Crewcabber
1983 - 2012 Ranger & B-Series
Jul 6, 2014 06:32 PM
car42jam
Apr 25, 2012 04:21 PM
jpwestco
Feb 24, 2012 06:48 AM
