Sponsored by: Auxito
Ball Joints How to check
Old Dec 28, 2004 | 01:11 PM
shane7209's Avatar
shane7209
Any idvice on the best way and what to look for on ball joints. Just got a call from the alighnment place price went from 59.95 to over 700 bucks. Front tires were wear but i was also due for new shocks which i know bad shocks will eat tires on this truck. So i replaced them this weekend and fiq at 160 k never had an alignment why not.
Thanks in advance
Old Dec 29, 2004 | 01:10 AM
Racerguy's Avatar
Racerguy
To check the ball joints you need to use a floor jack or jack stand under the lower control arm to support the truck. That "unloads" the ball joints. Look closely at the ball joints while someone pushes and pulls the top and bottom of the wheel. If you have more than about 1/32" of sideways movement from any ball joint it should be replaced. Also have someone pry up on the wheel with a pry bar between the ground and the bottom of the tire. If there is more than about 1/32" of up and down play then the joint is shot too.
Ford says, for warranty purposes, that any more than .080" of play the joint is worn out and needs to be replaced. Most techs I know feel that spec is way too much. They are worn out before that.
Old Jan 9, 2005 | 09:16 AM
GORDYSBRONCO's Avatar
GORDYSBRONCO
Same Thing On My 2000 F-150 $39.99 Each I Think It Was. At Autozone And They Will Let You Borrow The Ball Joint Press You Will Need
It Was A Pain To Do But I Need The Extra $640 More Then They Do
Old Jan 9, 2005 | 10:56 AM
shane7209's Avatar
shane7209
Thanks Racerguy. Ya think I will do them myself if they turn out to be bad.
JSOHC
Nov 16, 2015 06:39 PM
kefrko
Mar 31, 2015 07:14 AM
hedhntr
Mar 4, 2012 08:40 PM
93coleman
19
Nov 23, 2010 05:01 PM
Ringer97
Apr 10, 2009 09:55 AM
