Sponsored by: Real Truck
Quandary over Mirrors
Old Dec 28, 2004 | 07:50 AM
Lnd Svyr's Avatar
Lnd Svyr
My wife gave me a check for $350 to be spent on new TT mirrors (I've got the sports). She knew there was a good chance I'd freak if she went ahead and had them put on as a surprise xmas present (since I'm pretty darn picky about everything). A good thing, too, as I am not so sure about replacing the sports, now. Oh, in the beginning I really wanted the TTs but now I'm not so sure. The sports have grown on me. She's pushing me to call the dealer to place the order.
Anyone gone from sports to TTs and not been happy? And why?
Is there really any better visiblity with the TTs?
I currently do not tow so there's no reason there.
I believe the replacement will be simple thanks to all the data here on FTE.
I suppose I could hang on to the sports and go back if I don't like the TTs.
Then again, it is time for the transmission flush and that's about $170 I hear.
Thanks,
Reid
Old Dec 28, 2004 | 08:16 AM
Frobozz's Avatar
Frobozz
The TT mirrors take a little getting used to - you now have 5 different places you can look (including your windshield mirror), and they each have their sightly different purpose - but I think there are no better mirrors out there. In fact, I really really miss them when I'm in "mere mortal" vehicles with standard mirrors. But as goofy as they look on the trucks from the outside, I guess it would really look strange to put them on my son's '82 Mercedes diesel!
Duncan
Old Dec 28, 2004 | 08:29 AM
HeavyAssault's Avatar
HeavyAssault
I swapped in the TT mirrors on my '99. I agree with the added visibility and you can arrange the upper and lower to view different areas. I use the larger mirrors for traffic and the lowers for backing up. The smaller mirrors help as well during traffic for the blind spot. I suggest looking around on EBAY before you go to the dealer, you can install them your self. You could save a few bucks overall. What year truck do you own?
Old Dec 28, 2004 | 08:37 AM
1wheel's Avatar
1wheel
As I have just converted from an 1998 Expedition to a 05 F350 CC LB SRW, I really need to use the TT mirrors. There is still a very large blind spot in the flat mirrors and I have just purchased the C-Better round additional mirrors to aid in my getting used to the truck (~$50 is much less than smushing a car/snow bank). I will likely remove them after 1 year. I am also going to install a bed cap, so the center rear view mirror will be of very limited use.
Good luck with your truck..
Old Dec 28, 2004 | 08:39 AM
CmprSpecial's Avatar
CmprSpecial
I didn't even look think twice before I replaced the sports with the tow mirrors.. I also added the c-betr mirrors. I now can see almost as good when backing up as going forward.
I even got a complement once from someone who was watching me back through a tight spot "nice truck control" he said.
Wouldn't give them up for the world...
Old Dec 28, 2004 | 04:43 PM
nisiar's Avatar
nisiar
Duncan
Does this mean you have five glare points to deal with at night?
Old Dec 28, 2004 | 04:48 PM
1wheel's Avatar
1wheel
The TT lower convex mirrors cause very little glare. The center if auto-dim is not too bad. The larger flat TT side mirrors are glare issues, however, the TT do offer better blind spot coverage (drivers side) and comparable on the passenger side (flat and convex vs. 100% convex).
Go to a dealer lot and try them out...
Old Dec 28, 2004 | 05:39 PM
Lnd Svyr's Avatar
Lnd Svyr
Mine's an '03. Crew Cab Lariat. FX4. I keep checking out all the SDs and most do have the TTs. But I've got to the point where I like the sports, too. They didn't look right before. Now, they do. So I don't know. Maybe I'll throw it back to my wife and let her make the call.
Reid
Old Dec 28, 2004 | 06:03 PM
jwdeats's Avatar
jwdeats
I already did what you are contemplating and I advise against it. I replaced my sports. I also added the C-Betters. My setup looks ridiculous, as I have three mirrors per side. I bet the setup costs me 0.75 mpg at 70 mph.
I would try some cheap convex stick-ons before I went to the TT mirrors. That should give you what you need. I only look at my C-bettors (convex) currently, so I think if you had convex, that would do the trick. I wish I could just get a sport mirror that was a little bit convex--I think that's all you need for towing or otherwise.
Old Dec 29, 2004 | 06:53 AM
Lnd Svyr's Avatar
Lnd Svyr
Problem solved. Wife says we're getting the mirrors. Oh well, it's only money. If I end up not liking them, I can probably sell them at not to big a loss in the local trading post (refuse to do ebay). Thanks for your comments. Jwdeats, I hadn't considered the MPG loss--now that'll bug me if it turns out so.
Reid
Old Dec 29, 2004 | 07:17 AM
CmprSpecial
Most Super Dutys are high enough that the lights from vehicles behind you are not a problem.
Old Jan 4, 2005 | 08:16 AM
crbourret's Avatar
crbourret
Thumbs down TT's
I replaced my sport mirrors with the TT on my 99 F250SD because I tow an enclosed motorcycle trailer. They took a little getting used too, but are much better while towing.
However, if you don't tow I don't feel it would be worth the money and added drag on the vehicle. Plus you really need to be careful when pulling up to drive-thru windows. Those TT "Elephant ears" hang way out!
Just my 2 cents worth.
CRBourret
Coventry, RI
Old Jan 5, 2005 | 12:32 AM
strattera's Avatar
strattera
TT's with C-Betters on my F350 have saved my bacon more than once, wouldn't go any other way.
Old Jan 5, 2005 | 11:56 AM
nummit's Avatar
nummit
Anyone have some power sport mirrors they want to sell? I have the TT mirrors and hate them.I never can get them adjusted to my liking,and they are so wide they barely fit through my garage door.
Old Jan 10, 2005 | 05:45 PM
miterman's Avatar
miterman
I did this. The flat mirror on the passenger side of my 02 drove me bonkers so I went to a windsheild shop to see if I could find a convex replacement. We looked and looked through the book and eventually discovered that another vehicle (I think it was the excursion) had the sport mirror available in convex on the pass. side even though the pickups only list the flat mirror. The guy had it replaced in ten minutes, it fit perfect, and I was on my way! Huge difference.
