Are batteries isolated?
Old Dec 27, 2004 | 11:42 PM
ColtM4's Avatar
ColtM4
I just bought new batteries 2 months ago and I drained the batteries on accident. Somehow my toolbox light was left on over the long weekend and drained the batteries. So the question is why did both batteries go dead? Aren't these batteries isolated so draining one won't drain the other?
question 2.
How much damage did I do to the batteries by draining them completely?
Old Dec 28, 2004 | 12:26 AM
wlihntr's Avatar
wlihntr
no, they are wired in series(neg. to pos. to pos. to neg.) will give you 12v from two batteries. if they were in parallel then it would be, neg. to pos. to neg. to pos. giving you 24v(like a trolling motor in a boat).
Old Dec 28, 2004 | 05:17 AM
vancouverpower's Avatar
vancouverpower
Also I don't think any damage was done to the batteries by running them dead, should be fine.
Old Dec 28, 2004 | 05:51 AM
V8muscle's Avatar
V8muscle
They are likely wired in parallel, neg to neg and pos to pos.
Hooked in parallel, amperage doubles (assuming similar batteries). Amperage is what you really need on the cold mornings when you are starting that diesel. Hooked in series, neg to pos (like a flashlight) results in doubling the voltage.
You also probably did not damage batteries.
Old Dec 28, 2004 | 06:01 AM
Torque1st's Avatar
Torque1st
Posting Legend
A dead battery will freeze. Sometimes not enough to ruin the case but enough to damage the plates.
Old Dec 28, 2004 | 07:14 AM
Frobozz's Avatar
Frobozz
Not just likely, it's a fact! In series, it would be a 24V system (or they'd need to be 6V batteries.) Because you can't buy a battery with upwards of 2000AH capacity, or because it wouldn't fit in one spot under the hood even if you could, Ford gets the needed capacity by using two fairly standard heavy duty batteries wired in parallel, tucked in on either side of the engine compartment.
Duncan
Old Dec 28, 2004 | 09:57 AM
wlihntr's Avatar
wlihntr
Duncan
i guess i got my series and parallel backwords...it was late, i was tired
