Brake Line Leaks
Old Dec 27, 2004 | 10:20 PM
BoomerPower's Avatar
BoomerPower
Question Brake Line Leaks
On my 1980 F350 there is a leak in the rear brake line somewhere. I've checked it a couple times and i haven't found a place where it is broken. It's just a small leak because I have to add fluid to the resivior every once in a while. What should I do?
Old Dec 27, 2004 | 11:04 PM
Zane M's Avatar
Zane M
Have you checked the wheel cylinders? That may be where the leak is, not the lines.
Old Dec 27, 2004 | 11:10 PM
1984 f250's Avatar
1984 f250
yeh check there cuz my 84 go through them like you wouldnt believe
Old Dec 28, 2004 | 07:57 PM
85F_150driver's Avatar
85F_150driver
without looking at your truck i would say that its the wheel cylinders. Mine does the same thing so i would guess thats your culprit.
Old Dec 28, 2004 | 08:47 PM
Mr. Finch's Avatar
Mr. Finch
If you go through them alot you should probably check the diameter of your brake drums, because that is usually causd from the piston extending to far, and either ripping the ruber seal, or comming out of the cylinder. Atleast that is what I would say is the reason if they were disk, I have not done much on drums, but I would assume the same thing is possible.
Old Dec 30, 2004 | 09:55 AM
GLR's Avatar
GLR
Als.o check the MC cover gasket
Old Dec 30, 2004 | 06:41 PM
plowpusher's Avatar
plowpusher
check between the master cylinder and booster for a leaky master seal this usually shows up as a dribble track on the booster check rear brake adjustment frozen self adjusters will cause the rear brake cylinders to have excess travel and they will leak another place to look is along the frame for rust brakelines
Old Dec 31, 2004 | 12:38 AM
1984 f250's Avatar
1984 f250
when i replace them i go to the junk yard and get them for free so i dont care what happens
