Replacing Corroded Connectors
Old Dec 27, 2004 | 09:43 PM
cdanbarnes's Avatar
cdanbarnes
I've just finished rebuilding the engine for and 86 Bronco II and found that many of the wiring harness connectors in the engine compartment are badly corroded, one wire simply fell out of the connetor (years of exposure to salted roads). The wires themselves appear to be okay. Instead of replacing all of the harnesses, would there be any problem with just replace the connectors? If so, where can I buy replacements, either the connector itself or the metal terminal inside.
Thanks,
Dan
Old Dec 28, 2004 | 12:58 PM
Franklin2's Avatar
Franklin2
Besides a junkyard, I don't know where you can get connectors that are factory. It would not be factory, but I think I would use a male and female spade crimp connector till I found something better. Try to find the ones that have the plastic over the whole connector, then you don't need to tape them up. A little bit of the grease they give you with sparkplug wire kits would keep the water out.
Old Dec 28, 2004 | 10:13 PM
74F250's Avatar
74F250
fordfuelinjection.com............ryan has great products and tech info...he can remake your harness or you can buy a rebuild kit for yours...
bruno2
Feb 16, 2014 02:06 PM
Stangfire
1997 - 2003 F150
May 27, 2011 07:31 AM
ford2002f150
1997 - 2003 F150
Aug 4, 2010 12:49 AM
fairlaniac
1983 - 2012 Ranger & B-Series
Sep 12, 2008 01:08 PM
