1978 - 1996 Big Bronco
Cheap Power
Old Dec 27, 2004 | 07:59 PM
StagMan's Avatar
StagMan
Cheap Power
I have a 96 XL with a 5.0 302 and an E40D auto with manual 4x4 and hubs. Everything is stock except the exhaust which is Flowmaster Series 50 Duals. I want some cheap upgrades like chips or something like that which won't drain my account. I am Active Duty Air Force so my budget is not so big.
Thanks,
Jw
Old Dec 27, 2004 | 08:38 PM
masterkiller214's Avatar
masterkiller214
Underpulleys made a big difference on my 91,they were like under $100 from Summit. Didnt feel much difference with the K&N.
Old Jan 2, 2005 | 12:24 AM
YankeeFan's Avatar
YankeeFan
Forgive the ignorance but what are un derpulleys and where do they go?
Old Jan 2, 2005 | 12:37 AM
WhëëlMå1's Avatar
WhëëlMå1
Underpullies are at home on mustangs, not trucks. What exactly is your budget? That will help us tailor products to your needs.
Old Jan 2, 2005 | 12:39 AM
WhëëlMå1's Avatar
WhëëlMå1
They are different ratio pulleys that replace some of your existing units. They are said to decrease drag on the motor, which frees up power. It is well documented that on trucks, you run into cooling and charging issues.
Old Jan 2, 2005 | 11:10 PM
macruadhi's Avatar
macruadhi
A k&n filter is great. I got one on my 351 and I noticed more power and my fuel milage went from 250 to 300 miles a tank.
Old Jan 4, 2005 | 11:03 AM
DcSkater602's Avatar
DcSkater602
im looking at underdrive pulleys.. What material gives you good power. Aluminum... steel? Will the aluminums bend? Also once you install the new pulleys will the stock belt still fit on?
Old Jan 4, 2005 | 06:04 PM
rudder9's Avatar
rudder9
I Have An Aluminum Set By March. That Was One Of The First Mods I Made.that Coupled With A Good Exhaust And A Good Air Filter Will Give You Some Power And A Little Mileage Increase. I Als Reccomend An Msd Coil And Good Set Of Wires. Don't Bother With A Chip. I Bought One When I Was Mostly Stock And They Only Work At Wide Open Throttle,which Isn't Very Often In A 6000 Lb. Vehicle. After All My Mods I Had A Custom Chip Burnt By A Specialist For The Parts That I Had Changed. Hope This Helps And Good Luck With Your Project..
Old Jan 4, 2005 | 06:28 PM
stevef100s's Avatar
stevef100s
I don't think you can get a chip for a 96, but you can get something like a reprogrammer. I could be wrong though.
640 CI Aluminum FORD
Exhaust Systems
Jul 6, 2011 01:26 PM
2009 - 2014 F150
Jun 6, 2011 10:01 PM
debargew
Apr 9, 2007 12:10 PM
BigBlockGuru
1983 - 2012 Ranger & B-Series
17
Apr 12, 2004 06:50 PM
