High Pressure Pump 7.3psd
Old Dec 27, 2004 | 06:18 PM
greengobblin's Avatar
greengobblin
I HAVE A QUESTION, THE PUMP IN THE INJECTION SYSTEM FOR THE INJECTORS USE HIGH PRESSURE OIL ,I GET THAT PART I'M USED TO THE OLD 7.3IDI'S.I'VE BEEN READING THAT THE REGULATORS GO OUT & FORD WILL REPLACE THE WHOLE PUMP ,IS THAT REALLY NEEDED,OR CAN YOU JUST REPAIR IT ? CAT USES THE SAME SET UP ON THE LARGER ENGINES AND SOME CAN BE REPAIRED .IS THIS THE SAME WAY?ANY INFO? THANKS!
Old Dec 27, 2004 | 06:29 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The use of all CAPS is considered yelling on the forums.
The oil pressure regulator is easily serviced and can be replaced seperately from the pump.
Old Dec 27, 2004 | 06:36 PM
greengobblin
sorry !!! cookie88
Old Dec 27, 2004 | 06:40 PM
cookie88's Avatar
cookie88
FTE Emeritus
No worries, it's just hard for me to read all caps.
Old Dec 27, 2004 | 06:52 PM
greengobblin
i apologize again! i'm still new to the site and somewhat computer dumb!!! bythe way will that pressure regulator set up you have on your truck work on a95 psd? thanks
Old Dec 27, 2004 | 07:06 PM
cookie88's Avatar
cookie88
FTE Emeritus
You could plumb in an external regulator to yours, but you already have a full flow return, so you can adjust your fuel pressure by simply shimming the stock regulator.
Old Dec 27, 2004 | 07:18 PM
Quadzilla's Avatar
Quadzilla
If I'm reading him right, he's talking about the high pressure oil system, not the fuel system.
Old Dec 27, 2004 | 07:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
You are correct, we were talking oil system, but the only external pressure regulator visible in my gallery is my fuel pressure regulator, so I assumed we switched to fuel.
Old Dec 27, 2004 | 07:28 PM
greengobblin
where is the regulator located.i just purchased this truck and i'm not to familiar with this system i used to the old system. thanks
Old Dec 28, 2004 | 11:36 AM
cookie88's Avatar
cookie88
FTE Emeritus
It's on the drivers side of the fuel filter bowl. It's got the return line threaded to it and a couple of torx screws holding it on the bowl.
