o2 sensor placement?
Old Dec 27, 2004 | 11:32 AM
wipper's Avatar
wipper
i have an excursion with a 5.4 and the copmuter codes say sensor 1 in bank 1&2 are badbut i would like to look at them can anyone tell me where they are i know they are in front of the converters but where ? (it's 14 out and i just feal like lying in the snow for an hour to find them)
Old Dec 27, 2004 | 04:39 PM
wipper's Avatar
wipper
so i went under the truck and the sensors looked fine unhooked the bat and cleared the code restarted the truck and the service light went out so i think i'm ok for now
Old Dec 28, 2004 | 11:32 AM
LxMan1's Avatar
LxMan1
Post the actual code next time. It could be a different problem showing a O2 sensor code.
Old Dec 30, 2004 | 12:25 AM
wipper's Avatar
wipper
the codes were po155 and po135
Old Dec 31, 2004 | 09:39 PM
wipper's Avatar
wipper
well the codes came back so i changed the two sensors pulled the neg. batt to reset the computer. drove the truck and the service light came back on. now what do i do???
Old Jan 1, 2005 | 09:47 PM
LxMan1's Avatar
LxMan1
Are you getting the same codes? Which 2 did you replace? The two next to the exhaust manifolds I hope. You might check for corrosion in the plugs and bad spots in the wiring.
Old Jan 2, 2005 | 02:13 AM
wipper's Avatar
wipper
i'll check when i get back from work
Old Jan 3, 2005 | 11:11 PM
wipper's Avatar
wipper
i went to auto zone to have tham check the codes and the same codes came up when i asked him to clear the codes he said if i get the codes cleared i would faail my inspection next june because the computer will show that a code has been cleared.
i'm seeing red so what the deal
ohya he said the code would clear on it's own after 30 starts
some thing does not smell right
Old Jan 4, 2005 | 11:29 AM
LxMan1's Avatar
LxMan1
once it is cleared it should pass. You can always unhook the battery for about 15 min. That should clear them too.
If after about 30 drive cycles, if the problem doesn't reoccur, it will clear itself.
VCB
Modular V10 (6.8l)
Dec 17, 2013 05:47 AM
bigblock427
6.4L Power Stroke Diesel
Jul 17, 2011 10:02 AM
joshiepoo
1997 - 2003 F150
Oct 19, 2007 10:29 AM
jandjtrucks
2004 - 2008 F150
Jun 8, 2006 11:20 AM
fastestmom1960
Aerostar
Oct 24, 2004 09:22 PM
