'86 2.3L camshaft timing marks
Old 07-08-1999, 11:22 PM
Bryan Crawford
Guest
Posts: n/a
My timing belt broke.
The mark on the camshaft sprocket is obvious.
But I can't figure out the corresponding
pointer to set the timing right.
The "pointer" is a plastic thing with three
definite ridges (they show in the observation
hole in the timing belt cover) but
no white mark to explain
where to line up the mark on the sprocket?
I set it to the middle mark & the engine runs,
Old 07-09-1999, 08:47 AM
Phillip Guidry's Avatar
Phillip Guidry
Phillip Guidry is offline
In my post concerning your t-belt installation,I advised that after laying the new belt on,with no slack on the drivers side,and turning the crank twice to make sure that everything lined back up,the cam sprocket pointer should have came back to the middle line! If you were off a notch, the pointer would have been way to the left or right,so you would have obviously known something wasn't right.The fact that it runs and you haven't complained about any power loss or other problems tells me you got it right! Congradulations !
Phillip
Old 07-13-1999, 07:48 PM
Mulletwagon's Avatar
Mulletwagon
Mulletwagon is offline
dionysius
11-22-2016 01:30 PM
tobyw
4 Cylinder Engines
08-25-2015 02:53 PM
fairlaniac
08-11-2009 09:07 AM
Jim88554
1997 - 2003 F150
11-17-2008 05:39 AM
jjp
27
08-15-2007 04:12 PM
Quick Reply: '86 2.3L camshaft timing marks
