cam installation
Old Jul 14, 1999 | 07:02 PM
Garry's Avatar
Garry
5th Gear
cam installation
I had a shop install a cam in my 84 2.0L ranger about 15,000 miles ago. Now I have to replace the cam again, but the shop that installed it before striped the heads on the retaining plate screws. I have to get this fixed soon so i can sell it, does any one know how i can get the screws out with out taking the cyl. head off.
Old Jul 15, 1999 | 07:02 AM
Phillip Guidry's Avatar
Phillip Guidry
cam installation
I know you must be upset,not only cause the head is worn but also cause it's waaaay in the back of the head!I'm sure you have tried a #3 phillips socket bit already? Your next move will be a chisel and hammer. Select a cold chisel with a narrow blade are a cape chisel{diamond point}.Place the chisel near the outer diameter of the screw at a steep angle to make the corner dig into the screw when you hammer it in a direction that will make the screw back up.Once you get it to move about 1/8 of a turn,they should be finger loose after that. You may want to remove the hood for easy positioning of your body and hammer as this will keep you from getting aggrevated.
Phillip
Old Jul 15, 1999 | 03:59 PM
Garry's Avatar
Garry
5th Gear
cam installation
Thanks for the idea, i'll give the chisle a try
Old Jul 18, 1999 | 07:35 AM
RICHARD's Avatar
RICHARD
cam installation
AbandonedBronco
135
Jun 14, 2018 05:48 PM
thatguy71
Sep 7, 2016 06:17 PM
jack orchard
Jan 21, 2014 07:40 PM
Handegard
Nov 3, 2011 02:53 PM
JaysRanger
18
May 16, 2010 02:45 PM
