90 ranger
Old Jun 7, 1999 | 09:46 PM
dorothee
Guest
Posts: n/a
90 ranger
I am having problems with my Ranger cutting off
while I am driving. I believe the problem is
electrical, but can not seem to locate. Any sugestions???
Old Jun 7, 1999 | 10:37 PM
Pastmaster's Avatar
Pastmaster
90 ranger
you might check a few things actually, Maybe you have a clogged fuel filter? It could be something with Fuel injection, maybe it's the tps switch or something.
It might help if you give a better description.
Old Jul 4, 1999 | 09:09 AM
RICHARD's Avatar
RICHARD
90 ranger
You probably have this repaired by now but you didn't indicate the year/model of your vehicle. Once my '86 Bronco quit cold on the interstate. I looked under the hood and the coil wire had come out of the coil. Plugged it back in and off I went. Make sure everything is good and tight.
Old Jul 6, 1999 | 12:29 PM
Sarge's Avatar
Sarge
90 ranger
Try this one out, it might solve your prob...
The bulkhead connector in the firewall-interior
area that has the routing for the main body harness might have a bent pin, corrosion, or the pins might have fell out of alignmeent. Take the harmess/connector apart, view each pin with a magnifying glass and see if its properly positioned. Also, check the coil and related wiring, the ignition switch too. I had a 69 ford country sqire with this saame prob, the bulkhead connector was the culprit---bent pins that made
intermittant contact...
Old Jul 7, 1999 | 12:32 PM
scoobie's Avatar
scoobie
90 ranger
I own a 94 ranger that was cutting out while under a load but not at an idle or while revving the engine.
This might help you.
Turns out my problem was ignition wires. I opted to changes plugs, plug wires and ignition wires at the same time. Runs like new again.
I hope this helps.
scoobie
Old Jul 22, 1999 | 07:08 AM
T W
Guest
Posts: n/a
90 ranger
I have a 1988 Ranger 2.9 L. I was driving down the road and the engine just cut off. I waited a few minutes, it would crank back up and I would drive a little farther an it would cut off again. The problem was a bad electronic control module. Its located on the side of the distributor. Check with parts store they will know what it is. Also it requires a special little tool (cost about 5 bucks) to install, makes it real easy. I replaced it and it no longer cuts off. Try other suggestions first, then check this one out!! The part was about 65 dollars.
Old Jul 24, 1999 | 08:46 PM
bud's Avatar
bud
90 ranger
mban112
32
Jun 13, 2021 08:58 PM
Rxmarty
Projects
Jul 22, 2016 01:15 PM
knteriele
Sep 14, 2015 09:36 AM
wildstang
15
May 17, 2015 07:28 AM
pat155
Mar 1, 2007 10:08 AM
