I am clueless when it comes to stereo's and whatnot, so i'll lay out the scenario.
I bought an Infiniti Reference component system, it comes with 6x8's, 1'' tweeters, and crossovers. The Speakers are gonna be hooked up using the snap on wiring harnesses supplied by Crutchfield, so is there anyway to hook up the crossovers without cutting/splicing wires? i'd like the installation to be as simple as possible.
The crossover is mounted next to the speaker, So you should not have to splice anything. If they are not mounted on the speaker, They will have Four screws. One set for input and one for output to the speaker.
[QUOTE=Squirrel RJ]is there anyway to hook up the crossovers without cutting/splicing wires? [QUOTE]
No. You will have to connect the wires from the wiring harness to the crossover box. From there you will have to run a set of wires from the crossover to the tweeter and another set to the midrange. Also make sure to maintain polarity of the wires. With component speakers, it's easy to mistakenly wire the tweeter and midrange out of phase. The speaker's manual should elucidate what I mean by this.
If you don't have a $4 wire stripper/cutter, you could use scissors and a razor blade. To connect two wires, use butt connectors found at any hardware store for a few cents.
When he installs his speakers the wire from his old speakers will goto the input on his crossover. He does not have to cut anything, Just buy some male spades or barrel connector and add some wire.
The adaptor is useless for using with a component set. If you use the factory wiring, you need to cut the factory speaker connector off, strip the ends of those wires, and connect them to your crossover input. You will then need to add some new wiring from the crossover outputs to the separate speakers. You can't use the factory connector because there are 2 separate drivers to connect. I suggest mounting the crossovers behind the kick panels, NOT inside the doors.
If your factory connector is a female, a regular spade connector will usually fit and plug right into it. Plug 2 of these into the factory connector, then run 2 wires from them to the input on the crossover. Then run the wires from the crossover to the speakers. Easy.
I just installed that Infinity components in my truck last saturday and I am having problems with it poping when I listen to a cd but it is fine when I listen to the radio.
Why is that? There's one big advantage I can think of to mounting in the doors: you only have to run one wire through that miserable little rubber conduit between door and body.
If you install the crossovers into the kick panels, how do you secure them?
Mine are stuck to the inside of the panel with velcro. They are not going anywhere. I can't think of any disadvantages of putting them there. Inside the door is an unnecessary risk, in my book. And, running 2 wires through to the inside of the door isn't any more difficult than running 1.
I'm not necessarily disagreeing, but...risk of what? Are you concerned about the impact of the door closing?
It is on the driver's door, where that little space is really cramped. Still, I suppose it's worth it, to have the crossovers in a better location. Especially so if you're using speakers like Diamond with the rear acoustic fill feature...
Inside the door panels is not the ideal location to mount crossovers because of the water that could "drip" into that area from the outside via the window seals. I used to have a set of MB Quart comps in which the crossover was installed inside the door panel. After 5 years, the screws on the crossover module were badly rusted.
Despite that, I have the crossovers of my new JL Audio XR components mounted inside the door panel in the area behind the speaker opening. There just wasn't a convenient place to mount them inside my regular cab Ranger. Your vehicle may differ. I used double-sided Velcro tape. I then draped a plastic bag over the crossover. This should adequately protect it from water.
