1978 - 1996 Big Bronco
more probs.....
Old Dec 26, 2004 | 02:16 AM
1983Broncoboy's Avatar
1983Broncoboy
Angry more probs.....
just had this happen last night, came back from a road trip and as i came off the highway, i heard a little grinding noise, my e-brake light came on and stayed on and my brake pedal has to be pushed farther than normal to stop. any ideas guys?
Old Dec 26, 2004 | 11:11 AM
kameronth's Avatar
kameronth
Maybe you need to replace the rear shoes?
Old Dec 26, 2004 | 01:04 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
Do you use your E-brake ?
Maybe cable is rusty and sticking.
Old Dec 26, 2004 | 06:23 PM
greystreak92's Avatar
greystreak92
The brake light comes on when the pedal travels farther than it should have to to bring the truck to a stop as well as when the E-brake is applied. I'll second kameroth's post. If the rear shoes wear too far down the gap between shoes and drum surface gets big enough that the pins will slip out if the wheel cylinders and the cylinders will just keep expanding until the pistons pop out of the bores. You really dont' want that to happen..its really messy.
Old Dec 26, 2004 | 10:37 PM
JBronco's Avatar
JBronco
Yup.
Also - a spring on one of the rears brakes may have broken. I've seen it happen, and the end result is a bunch of broken metal parts flying around in the drum because there is no tension without the spring and everything just sort of falls off.
Old Dec 27, 2004 | 02:40 AM
SproutW's Avatar
SproutW
I agree with everyone and do yourself a favor. Buy a new spring kit when you put new brakes on the rear. They are cheap and the old springs lose tension with all of the heat generated over the years.
