1978 - 1996 Big Bronco
Do Electronic Rust Inhibitors Really Work?
Old Dec 25, 2004 | 07:55 PM
tom2131968's Avatar
tom2131968
I installed one on mine that I got off of a wreck but wonder if they really work. Has anybody got any tangible experience as to their effectiveness? Also, is one supposed to scrape the paint off of the area onto which the little boxes are installed?
Tom T
Old Dec 25, 2004 | 08:35 PM
tex94F250's Avatar
tex94F250
Just out of curiosity, how did the wreck look, did it have any rust? I'd guess that you'd need positive contact with metal. Always wondered why no one ever came up with something like the "zincs" on marine craft for a truck.
Tex
Old Dec 25, 2004 | 09:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
No, any electrical, electronic, or chemical (sacrificial) corrosion inhibitor needs a conductive medium to work. They work on ships and underground on pipes etc because you have water or moisture to work. Above ground (in the air) they will not work.
Old Dec 25, 2004 | 10:01 PM
tom2131968's Avatar
tom2131968
The vehicle, if I recall correctly, was a 1996 Dodge Intrepid and had no rust of note. I specifically looked at the rear brakke drums and they were virtually rust free as well. The reason that I ask this is because I thought it was snake oil as well but noticed that many factory vehicles were coming with them installed.
Hey torque. Would moisture, which causes rust and is a conductive medium when the truck is wet, allow this device to work at least until the moisture evaporates?
TomT
Old Dec 26, 2004 | 10:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
No, the moisture required for the "electrochemical cell" has to be continuous. A moisture film is not conductive enough to transfer the ions over long distances. The other type of localized corrosion called "oxygen concentration corrosion" is not hindered at all and it is probably the most damaging.
