Having trouble getting my door panel off..I've heard a few different versions on how to get it off but without a proper diagram Im a lil shook because I dont want to damage anything..
my main goal is to get some pioneer speakers installed instead of my stock speakers
Welcome to the only family Ford Truck site, on the net. The members in this forum are very knowledgeable about these trucks; they will eagerly help you…with your question.
To insure a better understanding of how FTE operates, please read the guidelines, and the READ FIRST notes in each forum you choose to visit. I'm sure you'll find plenty of reading and information to surf though.
Enjoy FTE
Door panel removal is pretty easy with little chance to cause any damage. Start by removing the two screws by the handle and the small plastic piece around the handle. A small screwdriver is all you need for the plastic piece. Once that is done start at one of the bottom corners and pull/pry to get the panel off. You can use a putty knife or buy a tool for this purpose. Once you've loosed one corner use your hands and pull the panel off on the bottom, front and back sides. Lift up to remove the panel from a channel and the lock button on top.
The panel is held in by plastic push connectors. If any stay in the door, remove them and put them back on the panel before replacing. If you destroy one or two, they can be purchased at the dealer of auto parts stores. You will also have to remove the power window, door lock and mirror controls if you want to completely remove the panel.
First time takes about 15 minutes, subsequent removals should be five minutes or less.
