'91 short Eddie Bauer 4.0 E4WD. First snowy and slippery weather....and on one crossing car hit the steet verge (right word?) by right front wheel approx. 30 km/h
Immediate damages: Bent steelwheel and driver is little bit shamed.
After driving back home discovered that wheel alignment is not correct anymore. They set so divers side tire poinst straight ahead but passengers side points little to right. And when trying to drive some noises: under light throttle at around 70 km/h some sort of growl / slight vibration in the floor and body. The condition seems consistant with engine rpms and if i take my foot off of the accelerator, the noise / vibration goes away. And accelerating to 100 km/h the grovl/vibration reduces a little. And I think transmission is not generating those noises...
What to suspect to be broken?
Did not tear anything apart but visual inspection:
Steering linkage seems to be ok. Lower A-arms seems to be ok. Tire endplay in both 12-6 and 9-3 way are the same on both sides so I thing bearings are ok.
Hi Harri - good to see another fellow Finn here. I have a '91 ext 4.0 AWD myself. Just did the wheel bearing replacement on driver's side. Even if it might not be current in your situation, be aware that the wheel bearings go quick - read that very quick - in the AWD's when they begin to show symptoms. Changing it wasn't bad at all. If you need any help PM/email me or you will also find me on the overdrive forum in Finland.
Evidence that something is bent you cannot see. If you are going to continue driving the van, at least disconnect the E-4WD module located under the driver's seat. This will prevent unecessary transfer case lockup and possible damage to the electrical components within. The lower control arm is fairly hefty but the outer and inner tie rods are fairly thin and will not withstand hard sideways impact such as you describe. I would bet at least one of those rods are damaged on that side along with the bent wheel as described in your post. In straight line driving, a severely off-center steering wheel is also evidence of damaged steering components. Best schedule an alignment soon after replacing that wheel. As someone else suggested, keep an eye (and ear) on the wheel bearing for future problems.
Where is that module, is it visable?? I have a feeling the AWD is not working on mine as when the rear was stuck the other day just the rears spun while the fronts didn't even try!!!
Sorry about the thread hijack but I am pretty sure I now know why I don't feel like it has AWD, what would be the reason for the module being missing, the van has covered 30,000 in 18 months and has been fine, no abnormal noises from the front, but the module is not there, just the black plug that I asumed to be part of some electric seat setup (I don't know why one would need 15 wires going to the seat but I just wasn't thinking straight) could I be opening a can of worms by plugging a new module in, the sales person sold it to me in winter and the suposedly working AC wasn't even connected and when I sorted out the electrics I found the compressor to be faulty. I'm a bit concerned that pluging the module in will lock up the front end or something.
O dear you really got stung there. Never ever trust a car sale's person they are the most devious people on this planet. As for the missing module get another and plug it in, it wount do any harm.
STUNG, they pulled my pants right down and greased me up, saying that, the engine is perfect, the transmission oil pump/front seal went not long after I got it (not the best job to do in the snow and no garage) but that was from sitting around not being used, the body work is immaculate as is the interior, I'd rather repair machanical stuff than rot. I'll be off on friday to pick up the module, a wreckers only want $50 for one, a cheap price to pay for the repair of AWD.
