Code reader
Old Dec 25, 2004 | 10:50 AM
HVJ's Avatar
HVJ
Question Code reader
Hi <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
I have looked for a code reader to my truck 1993 Ford F-150 5,8 and I have found model
Equus 3145 Ford Code Reader at $36.95; is there anybody who this model and knows if its is ok?<o></o>
Or is there a better model on the market at a reasonable price?
Old Dec 26, 2004 | 12:03 PM
david c's Avatar
david c
code reader
That is the one I purchased and that price is good. It comes with a booklet with instructions and codes. Once you read a code it is a process to determine what is exactly the problem. You will need a repair manual as well.
Good luck, David C
Old Dec 26, 2004 | 12:39 PM
HVJ's Avatar
HVJ
Thanks!
I'll try ordering it.
Old Dec 27, 2004 | 01:14 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
don't waste your money. the hanes manual will give you the code #'s and tells you how to use a multimeter. your can get a manual and a multimeter for less money and the multimeter is alot more useful
Old Dec 27, 2004 | 10:35 AM
mike L's Avatar
mike L
checking codes yourself
Welcome to FTE. You can check your trouble codes yourself, see how at www.fordfuelinjection.com under getting trouble codes. Its easy and free.
mike
