4180-c 4brl problems
Old Dec 24, 2004 | 02:04 PM
sacf250's Avatar
sacf250
i have a 4180-c holly carb 4brl that the eletric choke is taking the indel adjustment strait to fast idel. It will not let the carb and motor warm up. I dont know how to adjust it. can any one help. It takes me 15min in the morning before i can drive it. if I try to drive it it just stalls out.Im just about to go buy a new one. it is on a 87 bronco 5.8l
Old Dec 25, 2004 | 11:49 PM
LxMan1's Avatar
LxMan1
There are rivots that need to be drilled out and screws installed to move the choke cap to adjust it.
If you already have it loose, then you need to adjust it so that the flap closes with just a little tension on it when you open the throttle. It should start to open right after you start it then be fully open in a couple of minutes.
dylansf23
18
Nov 8, 2014 07:35 PM
CaseynWall
Mar 10, 2009 07:56 PM
jkrussell
Aug 1, 2006 05:24 PM
vito
May 4, 2005 07:24 PM
kuli48
Feb 11, 2003 01:50 AM
