Milky antifreeze
Old Dec 22, 2004 | 04:29 PM
fawey1's Avatar
fawey1
Unhappy oily milky stuff in antifreeze
I have a 1997 4cyl. ford ranger. Noticed a little anitfreeze in the driveway on two occasions over the weekend. No smell, present, oil and transmission fluid look fine. Took it to the garage today and the antifreeze looks like a milk shake. The garage changed out the antifreeze and wants to monitor it for a few weeks. I don't travel allot, but the truck is on the road 5 times or so a week on short trips. Please advise as to your thoughts on diagnosing this problem. I am new here and sure do appreciate it, not to mention I love my ranger.
Old Dec 22, 2004 | 04:53 PM
KitsKid's Avatar
KitsKid
Have you put a stop leak in the radiator? Bars Leak sometimes make the antifreeze look like that. OR worse case scenario oil is getting in your radiator. Most times it is antifreeze getting in your oil but stranger things have happened.
KitsKid
Old Dec 22, 2004 | 04:58 PM
fawey1's Avatar
fawey1
no stop leak
no stop leak added
Old Dec 22, 2004 | 05:30 PM
dafuz's Avatar
dafuz
Sounds like your blowing oil into your cooling systemwater. Maybe a leaky head gasket. Check the inside of yout oil breather cap. Shouldnt be milkshake like there either.
Old Dec 22, 2004 | 05:55 PM
fawey1's Avatar
fawey1
oil and trans fluid and cap, etc. look fine. haven't lost any oil or trans fluid and not enough antifreeze loss to notice. Could it be from not flushing the coolant for a long period of time?
Old Dec 22, 2004 | 06:04 PM
1081's Avatar
1081
you might have a radiator problem. If the tranny cooler lines go through the radiator to cool the fluid, you might have an internal leak. It might be worth having the radiator shop pressure test it. It could be slight enough that it doesn't show a big drop in the tranny fluid level.
Bryon
Old Dec 22, 2004 | 06:06 PM
Mil1ion's Avatar
Mil1ion
Sorry Guys,
This thread belongs in a TECH forum
The User Announcement forum is for User Announcement's (ie : I'm getting married) & Introductions, etc.
https://www.ford-trucks.com/forums/s...d.php?t=300691
Just a reminder to all user's to read the title of the forum & the text describing it.
Old Dec 23, 2004 | 09:09 PM
fawey1's Avatar
fawey1
breather cap looks okay
Old Dec 24, 2004 | 12:04 PM
fawey1's Avatar
fawey1
Unhappy Milky antifreeze
Hello, this is my second post, I apparantly put the first post in the wrong forum. I have a 1997 4 cyl auto. ford ranger. Love the truck. Saw a small amount of antifreeze on drive way. Not more than a 3 inch circle. Took it to garage, where they found the antifreeze to be milky in color. The oil and the oil cap look normal as does the tranny dipstick. I am getting heat, and the truck is running as usual. I really need some expert opinion on what the cause is. I don't want to run into an expensive repair only to find out that it is something else. Thanks for your help, and Merry Christmas
Old Dec 24, 2004 | 01:01 PM
hreed's Avatar
hreed
Probably the first priority is to find the leak. It may be a bad hose, water pump, or possibly just overflow. I would try to stop the leak, then flush the entire system (turn the heater on too), and see what happens. Usually oil contamination is the culprit when fluids turn milky. Possibly some transmission oil is migrating into the radiator. It's probably not engine oil but a compression check would let you know if that is something to check further. Good luck and keep us posted.
Old Dec 24, 2004 | 01:03 PM
fawey1's Avatar
fawey1
will do
thanks for your help, will keep you posted. probably get it back in the shop on monday or tuesday. again thanks
Old Dec 24, 2004 | 01:05 PM
fawey1's Avatar
fawey1
forgot to mention
I only saw the leak on two separate occasions, which was a small spot on the driveway. I haven't seen any leakage now for a week or so.
Old Dec 24, 2004 | 01:22 PM
hreed's Avatar
hreed
If you are taking it to a shop, have them pressure test the cooling system. That will tell you real quick if there are any internal leaks. I would still try to find the leak, even if it is small. Sometimes the water pump seal will start to fail and you will see fluid around the weep hole. If that is happening, the seal probably won't last much longer.
Old Dec 24, 2004 | 05:32 PM
el conquistador's Avatar
el conquistador
do the 97's still have the radiators with the plastic on the sides? i know about this time of year i get leaks from were the plastic and metal meets because of the cold.
thats if the puddle was at the front of the engine compartment. if not, where abouts was the puddle (front of engine compartment, back of engine compartment,...)??
Old Dec 26, 2004 | 05:14 PM
fawey1's Avatar
fawey1
Unhappy milky pinkish antifreeze
yes the plastic is on the sides of the rad. The leak is almost dead center under the engine, but it is not from the middle, it is runnin down along the tranny lines, can't find exactly where the leak is, could be from the overflow. The truck does not overheat, my son in law was over yesterday for Christmas and looked at the truck, he claims and I concur that the color of the antifreeze is a cloudy very light pink color. which seems to indicate tranny trouble. I need to know how to proceed to get this fixed, your advice is appreciated and really needed, thanks for your help.
