touch drive
Old Jul 6, 1999 | 09:21 AM
malonej's Avatar
malonej
touch drive
Is there a way to tell which component is bad in my 1986 2.9 Touch Drive 4X4 system. I think my computer inside the dash is bad because it won't click or do anything when I try to engage the 4X4. Is there a way to test this. What's the little white button and the red pilot light for on the computer? Is this a self-test function?
Old Jul 11, 1999 | 08:58 AM
RICHARD's Avatar
RICHARD
touch drive
My '86 Bronco II had the touch drive located over the rear view mirror. I found the little plastic "thingies" inside had broken off. I fashioned some replacements and put them in and to actuate the switch and it worked just fine. You might try that approach.
Old Dec 4, 1999 | 09:07 PM
David Burtle
Guest
Posts: n/a
touch drive
Hi
Mind does the same thing and I still have not found out what the problem is.
If you found out can you let me know as it's becoming annoying, snow is not far away and I don't want to spend a fortune having it diagnosed.
Thanks if you can help.
Old Dec 5, 1999 | 10:38 AM
Jim Karnes
Guest
Posts: n/a
touch drive
