dana 70 rear end
Old Dec 24, 2004 | 05:22 AM
lintgo's Avatar
lintgo
dana 70 rear end
I have a 1993 E 350 dually with a bad rear end. It is a dana 70 w/drum brakes. I can buy a 1999 E 350 rear end. It is a dana 70 w/disc brakes. What changes do I have to make to the brake lines to make the disc brakes work right? Thanks
Old Dec 24, 2004 | 02:37 PM
286merc's Avatar
286merc
First thing needed would be the proportioning valve as discs require a lot less pressure than drums. I dont know if the MC is different. As far as lines they should be the same but go under a 99 to be sure.
If possible get all you need, except lines, from the donor.
How on earth did you hurt the old one?
Old Jan 1, 2005 | 08:41 PM
ladder frame guy's Avatar
ladder frame guy
Thumbs up dana 70 rear end
I have the dually dana (spicer) 70 HD rear end on my '96 E 350SD, w/drums, 67K
mileage. Plan to reduce weight, swap out to single rear wheels(non-Bud). If
staying with drum brakes is easier, this one is 4.10 ratio, 9.75, axle code E2 90.
Found a few leads on single wheel axles, but should plan to sell the dually, what
state? Any interest? Post back, I'm flexible. Ladder Frame Guy.
Old Jan 1, 2005 | 09:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Lintgo... and Ladder Frame Guy.....two for one....Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
